Can anyone shed some light on how to remove the rocker moldings of my '52 Hardtop? I can find nothing about this here in my search. Thanks.
Removal of rocker moldings on '52 Commander.
Body / Glass: Removal of rocker moldings on '52 Commander.
Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
1952 V-8 232 Commander State "Starliner" hardtop ODTags: None
Thank you Terry.
Originally posted by dictator27 View PostPush a wide bladed putty knife (2 or 3 inches) under the bottom edge of the moulding and pry out gently.
TerryFrank van Doorn
Omaha, Ne.
Terrysigpic
Lark Parker --Just an innocent possum strolling down life's highway.
Thanks again Milt and David, appreciate all the helpful hints. My task this coming week is to remove the moldings and see if I can redeem them with a polishing job. If that does not work out to my satisfaction I will reluctantly shell out the bucks for a re-popped set of clips and moldings from Classic Enterprises.Frank van Doorn
Omaha, Ne.
Frank,
Pretty much as easy as already stated. It may be necessary to loosen the bottom of the front fender to extract the "tabs" that David mentioned. That little front plate is spot welded stainless to the body of the molding. There is no sense in re-welding stainless if you can avoid it.
Make a note of the molding clips, which side is up and which side is down. The reproductions are easily installed but are pretty much a one time application. Get them in upside down and you might as well purchase some more.Brad Johnson,
'56 Sky Hawk in process
