Sometime here soon , I'm going to take off a valve cover on the 259 and paint them,and was wondering do I put permatex around the grommit before installing it on the valve cover. This is the first time for me taking off the valve cover on a stude. I've taken off other covers on brand -x ,but was wondering 55 c body Thanks Mike
Grommits for the valve cover ( Do I use permatex on grommits to install on valve covers)
I never do. Just put them in my mouth a couple of seconds and get spit on them, in order to slip into the valve cover holes easier. Use the flat washer that is included, an if the stud is too short for the lock washer to include, leave it off a week or so till the rubber settles a bit. Don't tighten the covers too tight either; come back in a week or so and re-torque gently. I am sure there's a torque spec somewhere, but I'd guess 45-60 inch pounds.
Afterward, its a good idea to re-check the torque about every 5000 miles.
RTV Silicone High Temp Black Permatex Brand sealer, works great if LIGHTLY applied to the Neoprene type Valve Cover Gaskets with New Grommets (DRY) using flat washers.StudeRich
The top rubber grommets I have never used sealant of any sort on. I always use No2 Permatex
on the bottom gasket to hold the gasket to the valve cover, and dry where it seals to the head.
Tom'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
Originally posted by sbca96 View PostThe top rubber grommets I have never used sealant of any sort on. I always use No2 Permatex
Tom
Another trick is to use the Permatex #2 to stick the seals in place inside the covers, then set them upside down somewhere, with about 20 pounds of weight on top and let them dry. That way, the seals stay in place, making it much easier to maneuver the covers back into place. That's especially helpful on the GTs, which have several obstacles to maneuver around in getting the covers into place.Last edited by JoeHall; 04-20-2014, 03:54 AM.
