Have a 1951 Champion needing core plugs and coolant cleanout. How do you remove the oil fill pipe in order to access the core (freeze) plug directly behind it? I've tried the Studebaker manuals (shop, chassis, etc) but none show or tell how to remove the fill pipe in order to pull the core plug. I have removed all the other plugs without any problems. I did discover massive amounts of debris and some wire inside the coolant passages and was able to remove a lot of it but no success on the first core plug because the fill tube is blocking access.
Oil Fill Pipe Removal For Freeze Plug Change
Tags: None
Originally posted by studepack View PostHave a 1951 Champion needing core plugs and coolant cleanout. How do you remove the oil fill pipe in order to access the core (freeze) plug directly behind it? I've tried the Studebaker manuals (shop, chassis, etc) but none show or tell how to remove the fill pipe in order to pull the core plug. I have removed all the other plugs without any problems. I did discover massive amounts of debris and some wire inside the coolant passages and was able to remove a lot of it but no success on the first core plug because the fill tube is blocking access.
Popped it out without any damage.
Used a 2x4 (flat on the top and tapped down with a hammer) to reinstall, also without damage.HTIH (Hope The Info Helps)
I just did a filler pipe removal on a 1949 Champion engine. I tried hose clamps, vice grips and a slide hammer but nothing would move it. With the engine upside down on a stand and the oil pan off, I used a socket that was just a hair smaller than the hole in the block and started hitting it with a 4lb hammer. Took quite a bit of pounding but it came out without any damage.Rick
Kingman, AZ
I pulled the one on my 2R5 pickup by carefully moving it back an forth while pulling up on it and it eventually came right out, so I could then access the freeze plug behind it that had started to leak.Dan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
