The weather has warmed up enough that I can heat my shop and get some work done. I tried doing some welding when it was 20 degrees but I would ice up the inside of my welding hood glass and I am blind enough without that.
Tonight I finished one exhaust manifold except for the exit port so those of you doing transplants like I did using a McKinnon and not being able to find the stock left side rams horn I can take some photos so you can see how I did it.
Yes I know that there are some magic block headers but I have seen what some of you had to do to the collectors to clear Stock Studebaker steering so I aint gonna do that plus Pinkie is high compression and I do not want those headers heating up my expensive high torque starter. I have one done and the other is half done and I am trying to decide if I want to just used my welded up one on the left side and use a rams horn on the right side.
My exhaust exits through the fender wells so I may just get lazy and put the rams horn on it all depends on how solid my current exhaust pipes are as they were done a bit more then 20 years ago and my glasspacks do have some long dents from bottoming out on mountain roads.
Here is my email so shoot me a message if you want photos.....hartcreek at bentonrea.com
Please put exhaust manifold as the subject so I can spot it better.
