Me again, just wondering if the 259 will bolt onto the 54's 6 cyl. motor crossmember pads or do I remove them and use the brkts. from the wagonier? Thanks--Steve
1959 259 from 64 wagonaire into 54 stude hdtp
Your stock frame mounts have 2 sets of holes. One set is for the six and the other is for a V-8. There are lots of other things to change from a six, but the frame mounts will work. Someone else will have to fill in the details."In the heart of Arkansas."
The '56 and newer V8 Rear Engine Mounts were changed from the 1954 style, so the holes for those in the Rear Engine support crossmember will need to be drilled.
Your Fuel line will need to be lengthened to reach the Left side and your Fan shroud will need to be modified to fit the Engine Fan location.
I welded a 1 In. strip on the Left vertical mounting flange of the 6 Cyl. Shroud and folded the Right mounting flange inside to make it move an inch to the right, also cut a fairly small hole it the left side, lower to clear the Steering reach Rod. I
lengthened the Batt. Box to fit the common Group 24, 12 Volt Stude. size Battery and most of the rest was bolt-in to a .060 oversize 289 for a very fast, built 299cid V8.
It did require a '56 and up Clutch Housing, Flywheel, Pressure Plate, Clutch Plate and Throughout Bearing for a V8 3 Speed Overdrive Manual Trans. and floor shifter.StudeRich
You could also grab the rear engine support crossmember from a later C/K. They bolt in. (That's what I did)
Originally posted by StudeRich View PostThe '56 and newer V8 Rear Engine Mounts were changed from the 1954 style, so the holes for those in the Rear Engine support crossmember will need to be drilled.
Sorta what I'm doing.
60 Lark 259 into a 54 Conestoga. And I'll be doing another of the same thing after this car is on the road.
The front mounts, redrill in the opposite pattern. That is, put the right side mount on the left and the left side mount on the right, redrill accordingly (use the opposite side mount as a pattern).
For my swap, that all that's stock. Electric fan inside the original fan shroud, different accelerator linkage, GM trans., thru bolt front mount pads, home made mid-mount (behind the engine, in front of the trans), custom driveshaft, new, full fuel line comming in from the right side of the car.
The front mounts, redrill in the opposite pattern. That is, put the right side mount on the left and the left side mount on the right, redrill accordingly (use the opposite side mount as a pattern)./Cut/Mike
That is one of the minor problems we have here, people note THEIR situation, which is similar but on a different model, which changes EVERYTHING. Just be careful to match the info to your model and year. Mike's info only works on Champion Sedans and Wagons not on the OP's "K" Model.
And Ed, are you sure you are referring to the Rear Engine Mount holes in the crossmember of a '53, '54 CHAMPION "K" Body being converted to a later model ('56 & up) V8 Engine and Bellhousing? Because I KNOW I drilled my Standard Trans. Clutch Housing/Engine Mount holes.Last edited by StudeRich; 01-24-2014, 04:43 PM.StudeRich
I bolted in a 62 Police Marshal 289, and hd automatic into a 54 Champion ht. It bolted right in with no modification of the frame mounting . I had to cut the driveshaft center bearing support out for the 1 piece drive shaft, but that was it. The driveshaft was 1/2 too short, even with the dana 44, so I drilled the axle spring perch to compensate, and you would be hard pressed to visually tell. I did this when I was 11 it was my first car, but I couldn't drive it!Bez Auto Alchemy
Originally posted by bezhawk View PostI bolted in a 62 Police Marshal 289, and hd automatic into a 54 Champion ht. It bolted right in with no modification of the frame mounting . I had to cut the driveshaft center bearing support out for the 1 piece drive shaft, but that was it. The driveshaft was 1/2 too short, even with the dana 44, so I drilled the axle spring perch to compensate, and you would be hard pressed to visually tell. I did this when I was 11 it was my first car, but I couldn't drive it!
I wish it was twenty years.....my body says otherwise! that was back in 1971Bez Auto Alchemy
