Another interesting and very useful welding rod I've recently tried is called "Extracto Rod". We've all experienced bolts or studs that have broken off either flush with or down inside a cast iron engine block, cylinder head, manifold, etc. This rod is used at lower amperages (60-80). The idea is to weld onto the top of the broken stud...a little tricky...rod must be kept dead center, and as perpendicular to the broken stud as possible, then the weld is built up and out of the threaded hole. When the weld is high enough, a nut is welded on, which can then be worked back and forth with a wrench, loosening the broken off bolt.
The combination of the heat from the arc welding, and this twisting action, USUALLY works. The unique thing about this rod is that as it's flux coat melts and spatters inside the threaded hole,...the flux clings to and actually PROTECTS the threads, insulating them from the welding spatter. Also, the weld itself seems to be able to handle the twisting (torque) 'back and forth' action on the broken off stud or bolt quite well.
