I finally got around to adjusting the valves on the Hawk today. Guess I'm concerned because I couldn't even come close to getting the .026 feeler gauge in any of them. Had to turn the adjusting nut quite a bit to get them set. I have them set and will put the valve covers, etc., back on tomorrow and hope for the best! It concerns me because the car started good, idled good and ran quite well. It did seem to lack power, but since it's my first Stude, I'm not sure how much power it should have. Compared to my 265 V8 (stock) in my 56 Belair, it seemed doggy. Are my concerns warranted, or is it no big deal they were that tight? And by the way, I did go by the procedure in the shop manual.
Valve Adjustment 289
Got it together. Now sounds like a diesel! RPMs increased by about 300 at idle and I can't seem to get that adjusted back down? It definitely has a bit more pep, but way too noisey....... Not sure what to do.
As I mentioned, I set them cold and used the test light for all but #1 cylinder. The procedure states to turn the engine until the test light comes on and then adjust that cylinder. I noticed the light stays on for quite a bit of the stroke when moving to the next cylinder, so should I stop when the light first comes on, or go a bit further?
It sounds to me like they were probably close before you adjusted them and now they are much too loose. A Stude V8 with the valves properly adjusted is virtually silent. I do it this way...
Adjust this valve With this valve fully open
1 intake 6 intake
3 exhaust 2 exhaust
8 intake 5 intake
6 exhaust 1 exhaust
4 intake 7 intake
5 exhaust 8 exhaust
3 intake 2 intake
7 exhaust 4 exhaust
6 intake 1 intake
2 exhaust 3 exhaust
5 intake 8 intake
1 exhaust 6 exhaust
7 intake 4 intake
8 exhaust 5 exhaust
2 intake 3 intake
4 exhaust 7 exhaust
Clark has a nice decription of the factory method here...
http://studeblogger.blogspot.ca/2011_06_01_archive.html
This method works too...
At TDC with #1 on the compression stroke adjust Intakes: 1-2-5-7 and Exhausts: 1-3-4-8
With pointer at 0 and #6 on compression stroke adjust Intakes: 3-4-6-8 and Exhausts: 2-5-6-7
Also...
intake opening - set exhaust / exhaust closing - set intake, method
In any case, your engine should be quiet when you are finished.
Your performance issue MAY be something else (timing, dwell, plugs, carburetion).
Also your comparison with your 56 Chev may be misleading. If both cars are similarly equipped (carburetor, exhaust, automatic), they would be close in an all out drag race with the Stude using first gear start. In normal driving, I think the Chev is going to FEEL quicker due to the lower first gear in the Powerglide compared to the second gear start in the FOM.Dick Steinkamp
Bellingham, WA
Clark's procedure is fine. The only things I might add is that using your thumb to feel for compression can be misleading. (I think this is what happened to you) This is where a TDC whistle comes in handy. It will not whistle on the exhaust stroke even though you will feel pressure against your thumb. Or you could just lift the distributor cap and make sure the rotor is pointing at #1 spark plug wire. The other thing is that the test light comes on when the points break, not when they close.Restorations by Skip Towne
Originally posted by Dwain G. View PostThe only things I might add is that using your thumb to feel for compression can be misleading. (I think this is what happened to you)
