I've searched out the forum regarding the removal of front springs ('64 Daytona). I have done this numerous times on other cars, but never on a kingpin style front end. I am NOT looking to rebuild the front end, I only want to replace the springs. Unfortunately the posts I've found basically talk about rebuilding the front end and go into greater disassemble than I need. Thus, there was a general absence to describe things that might fall out.
From what I've read the car is supported by the frame, the wheel removed, the sway bar released from the A-arms, the shock removed (and a chain secured through the spring for safety). A jack is placed under the spring pocket on the lower A-arm. The lower kingpin cotter pin and nut are removed. The jack is slowly released, the A-arm will drop and eventually detach from the kingpin and then...???
My concern is what parts (needle bearings, thrust bearings, seals etc.) might fall out and confound reassembly. It seems it would be wise to support (wire up) the spindle and everything attached to it to keep them from dropping too. My hope is that the A-arm drops, the springs are swapped and the process is simply reversed. Then again I've done things like this and something (that is never addressed) always comes as an unpleasant surprise.
Thanks, Tom
Thanks, Tom
