62 GT Hawk...why after a decent idle would the exhaust be so hot you can't put your hand on the exhaust tip??? Totempole.
Too Hot to touch
Generally, you should be able to block the tip with your hand for a second or two to observe exhaust leaks. If it's too hot for that, start with the timing.Brad Johnson,
'56 Sky Hawk in process
Check the Heat Riser Valve, when it is OPEN, on a Original Type the top of the hat shaped weight will point forward, or if a replacement Valve that is half round shaped, it will still go forward after warm-up.StudeRich
If by, "exhaust tip" you are referring to the end behind the rear bumper, that seems a little warm. OTOH, what are you calling a, "decent idle"? I have had them get so hot after idling say 20-30 minutes, in order to block off the exhaust with my hand, I needed to use a rag because it was too hot for the naked hand.
However, if the car has been moving down the road, it is not usually too hot to touch. I'll check the 62GT later today, when I get to my destination 23 miles down the road in an hour or so. I'll also try to remember to check when I get to the Louisville Street Rod Nationals about 75 miles from there later on today. The last few miles to there will probably involve several minutes of poking along in the traffic.
If you think it is excessively hot, check for late timing. Late timing will also make it idle slow, and have low power.
Hey Ed, did you get most of that warning off of a McDonalds or Jack in the Box Coffee cup?Originally posted by SN-60 View PostHEY!!!!...Exhaust systems get HOT folks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Yesterday, I checked the tail pipe as planned, behind the rear bumper. It was hot each time I checked it, but not blistering hot. Hottest was at the Louisville fairgrounds, after poking along in traffic a few miles.
To quantify "hot" we'd all need calibrated thermometers. So, still not sure how hot yours is getting, but as mentioned, its a good idea to check the timing anyway.
Hot is when You say "OUCH"!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Originally posted by JoeHall View PostYesterday, I checked the tail pipe as planned, behind the rear bumper. It was hot each time I checked it, but not blistering hot. Hottest was at the Louisville fairgrounds, after poking along in traffic a few miles.
Mine gets too hot to hold your hand over the tailpipe the exhaust is extremely hot...even after I reset the timing. TotempoleOriginally posted by JoeHall View PostYesterday, I checked the tail pipe as planned, behind the rear bumper. It was hot each time I checked it, but not blistering hot. Hottest was at the Louisville fairgrounds, after poking along in traffic a few miles.
Originally posted by Totempole View PostMine gets too hot to hold your hand over the tailpipe the exhaust is extremely hot...even after I reset the timing. Totempole
In all seriousness, if Your Hawk is running well, and is not overheating, I think that You might be worrying about a problem that doesn't exist.
