A note for anyone buying these "extremly" HIGH cost caps.
As they come out of the box...they are mostly usless as a "breather cap". And, they will only fit the rocker covers. I tried mine on the iron breather tube, the short alum. breather and the long alum. (pot metal) tube and it didn't fit any of them.
The two tiny little .128" (or so) holes in them will not even support human life..!
To make them work as designed, you will have to drill/grind as much of the "inner" cap away as you can. Just remember to not remove the material adjacent to the spring. Also use grease on the drill to hold as many chips as you can....then clean the cap as well as you can.
The design has changed, along with I assume the manufacturer, and that manufacturer/designer, knows nothing about air transfer.
Just a word to the wise....DO NOT expect actual "breathing" to take place with these caps until modified.
