Has anybody ever adjusted the finger height on a three finger pressure plate? I am putting a Mustang five speed in a Stude and using a Mustang clutch plate. The spring pack that surrounds the center circumference of the clutch disk is taller (larger diam springs) and the throw out bearing comes way to close to the springs. If I over adjust the clutch to get the pedal well off the floor when it engages, the bearing will actually hit the springs. I think if I adjust the fingers out further from the plate (away from the engine) i can get more clearance when the clutch is fully depressed.
Does changing the finger height just move the range fore and aft or is there more involved?
I am using the Stude pressure plate.
