I was looking for something on the SI site and I could swear I saw a listing for a fan shroud for a 170 Six for a 1960 Lark. This car doesn't have it, but did they originally come with a shroud?
Fan shroud
Saw one at the South Bend swap meet.
I know that they were part of a kit for dealer installed AC.
Have not seen that kit in a long time.
It's a real simple square of bent sheet steel that fastens to the radiator bolts and stands about 2 inches from the radiator core, with a circle cut out for the fan.
If I recall, I think it was an option. The cars that had V8's and A/C usually ended up with a fan shroud. I put one of Thibeault's fan shrouds on my car way back in 2004 or 2005 when he started reissuing them, on my '64 R2 Commander(along with new fan clutch, recored radiator, and the biggest fan Studebaker provided), and it helps alot. Instead of the air being whirled around past the radiator, it's now ducted through the fan instead. They weren't the most elegant of items, just a metal pizza box with a hole cut in the center, of course if you look at the front of a Lark, you can see the reason why from the lack of space up there between the fan and the radiator.1964 Studebaker Commander R2 clone
Anyone thinking of adding or fabbing a fan shroud, remember: Half the depth of the fan blade pitch should be in the shroud and half should be out. Does that make sense? Easier to illustrate it, but I'm not that tech savvy.KURTRUK
I had one for a while on my 62 Daytona and cant remember why I removed it. Right now it is still residing in the garage of my old house. It is simple enough of a design to make one on a simple sheet metal brake as Skyway said.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
as far as the distance the fan sticks out of the shroud...I knew a guy from GM performance who also raced and he said thru GM testing they showed the rear of the fan should protrude from the shroud by 1/2 inch only. that is how I build mine.1947 M5 under restoration
a bunch of non-Stude stuff
