Studebaker used the right rear cylinder head on V-8 engines for the line leading to the oil pressure guage but I was wondering if anyone had done research on the pressure difference between that location & the left front area on the head. Its the same location as far as the head goes but how much pressure loss would one expect based on a tight engine with no clearance problems.
Oil Pressure guage
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 autoTags: None
I have run a guage on every port in a Stude head (and a few other odd places) at one time or another.
The pressure read the same out of all of them, or was so close it didn't matter.
Did notice that the 'rate' of increase was a tad faster in the rear than in the front, but it was hard to see any real difference.
Engine looked stupid with 4 oil pressure gauges hooked up at one time...
Inquiring minds want to know
Originally posted by Warren Webb View PostStudebaker used the right rear cylinder head on V-8 engines for the line leading to the oil pressure guage but I was wondering if anyone had done research on the pressure difference between that location & the left front area on the head. Its the same location as far as the head goes but how much pressure loss would one expect based on a tight engine with no clearance problems.HTIH (Hope The Info Helps)
Thanks Jeff! I kind of figured you would be the one to know....LOL I just wanted to be sure in case it wouldn't be the same & I would then form a false conclusion.59 Lark wagon, now V-8, H.D. auto!
64 Zip Van
66 Cruiser V-8 auto
