I spent much of this weekend scraping the undercoating from a hawk I am restoring. I have used the aresol rubberized undercoating in the past and I can say without a doubt it can't hold a candle to the stuff they put on back in 59. What is this stuff? Is it still made today? What are the rest of you using? The asphalt based coating really did do a good job protecting the base metal and if I could I would put the exact same product back on the car. After all, it worked for the first 53 years. Any recomendations?
Undercoating
Tags: None
Originally posted by RDWEAVER View PostI spent much of this weekend scraping the undercoating from a hawk I am restoring. I have used the aresol rubberized undercoating in the past and I can say without a doubt it can't hold a candle to the stuff they put on back in 59. What is this stuff? Is it still made today? What are the rest of you using? The asphalt based coating really did do a good job protecting the base metal and if I could I would put the exact same product back on the car. After all, it worked for the first 53 years. Any recomendations?
This is about the best "substitute” for the old MORTEX I’ve found on the market today. It’s expensive and you’ll need to get the proper spraying equipment as well:
3M™ Body Schutz™ Rubberized Coating works as a protective coating with sound deadening qualities designed for cars, trucks and vans. The black, rubberized, coating bonds to a wide variety of surfaces and is best applied with our 3M™ Body Schutz™ Applicator Gun, part number 08997.
Good Luck!!!Last edited by Welcome; 02-10-2013, 10:42 AM.
Originally posted by Welcome View PostIt's MORTEX! More about it here and in other past SDC Forum threads: http://forum.studebakerdriversclub.c...ghlight=mortex
Good Luck!!!sigpic
55 President Deluxe
64 Commander
66 Cruiser
37 Oldsmobile F37 4 Door
I think the guy who put mine on in 1959 must have got in trouble from the supervisor for not using enough the day before, it was almost 3/8" thick in places. Actually a good thing it was cause the metal underneath is still new. I did not see any paint over it but the body color appears to be underneath it.
I'm re-doing a 50 Champion..The underside was sprayed and you are right some of it comes off about 3/8 thick. Some of mine is peeling off, but mostly intact. On a good note---I would say it's the original undercoat. So if you find it all over the underside, it'll give you an idea of what kind of shape it's in ( the originality).
From one Iowan to another---if you use that can aresol stuff---please wear a mask
Rick
Originally posted by bosshoss61 View PostI'm re-doing a 50 Champion..The underside was sprayed and you are right some of it comes off about 3/8 thick. Some of mine is peeling off, but mostly intact. On a good note---I would say it's the original undercoat. So if you find it all over the underside, it'll give you an idea of what kind of shape it's in ( the originality).[ATTACH=CONFIG]21298[/ATTACH]
Rick
I don't think I will put any thing on these days without a mask. I am getting older and smarter it seems.
