When I installed my vent windows today I found that they are not lining up correctly. I have replaced both pivot rods as well as the rubber seals.
Now the glass is not lined up correctly. It appears to fit correctly at the top pivot but the bottom is too far forward. Both windows have the same problem.The windows are difficult to shut and do not seal well. Also the tension bracket for the pivot rod does not seem to fit correctly on one of the vents. I've tried enlarging the hole in the seal a bit and also in the frame in order to move the bottom of the glass back without success so far.
I am attaching a picture. The picture is does not show how tight the front of the window is to the seal very well.
Any ideas what is going on.
thanks,
thanks,
