All,
Happy New Year. Need some help--I'm at wits end! Installing the oil pump and distributor in my '48 M5 (with a '49 IR 6 cyl engine). I've read all the posts and manuals on the topic (StudeRich's inputs really helpful in those).
My issue: When I put the oil pump gear in, the manual says to start with the key way at the bottom of the engine and as you pull it on to the cam gear it will rotate to the rear of the engine. Then, with the distributor pointing at #1 and the engine at TDC compression stroke (UDC on the vibration damper), it should all line up. I can't do that. I have to start with the key way pointing toward the rear of the engine and pulling it results in the key way pointing up at the top of the engine vice the rear. That is the only orientation that will allow me to have the distributor pointing to #1. I've ensured that I'm TDC on compression stroke on #1 cylinder and ensured I have the rotor pointing to #1.
My question: Is that OK? Seems that it would be but don't want to get this wrong!
For fun--added a pic of the new metal cam gear (nice piece).....and yes I lined the cam gear and crank gear up properly so think I'm good there.
Many thanks to all.
Many thanks to all.
