Too pretty to bolt on!
  • Engine: Too pretty to bolt on!
    Check out the nice machine work on this Stude head....done by a shop in Mass that does racing engine work.....hot tanked, checked for cracks, new guides, hardened seats and stainless steel valves.
    Went on a friend's '55 Speedster I did the upper end on about a year ago.
    Hauling jewelry around in the trunk of a C/K!
    Brad Johnson,
    '56 Sky Hawk in process
      I think I just got his brother back from City Motor Supply in Dallas! Not a racing head, and they baked it instead of hot tanking. New valves, guides, seals, etc.
      Wish I had a "before" shot.......
        Agreed. If this shop did all this cool work, they should of at least done some port/chamber work to go with the valves/seats/guides.
        They're leaving a lot of power stored up that a grinder in a skilled hand (race shop) could have released. Milage and drivability too.
        Sorry...had to say it.
          To: Chucks Stude,-------Couldn't pull up Your photos...?
            Sorry, I messed up. Here are the pictures.
            This head had wasps living in it, and several stuck valves. It is a work of art compared to how it looked before.
              To: Chucks Stude,-----Sorry Chuck,....I'm still not having any luck with the pics.
                Here are some before and after pictures of my 259 heads
                Mike was very kind to tutor me when I bit the bullet and ported and polished the heads on my 259. These are the before, in the middle of, and finished pictures. The Machinist here in Tulsa R&R the exhaust valve guides, installed hardened exhaust valve seats, milled the heads, and did a three-angle valve job for $205. Per his recommendation, the umbrella style valve stem seals were used on the exhaust valves and the positive seals on the intakes.
ID:	1676117Click image for larger version
ID:	1676118Click image for larger version
                Charlie D.
                  To: Charlie D,--------'Just a little' difference.........NICE WORK!!
