Regarding my fresh and complete Stude 299 (bored-over 289) rebuild: the engine shop instructs me to fire-up the motor static and immediately bring it to 1800rpm for 20-30 minutes - NO IDLING - to break-in cam bearings and rings. OK. My question is what to do about the fact that this motor is set up for an auto trans (Stude Powershift). It will have a dry torque-converter and trans at break-in. If I simply pull the trans, I can't imagine that even the torque-converter can run dry for that period at 1800rpm (or can it?), and I can't fill the system with fluid without a period at idle while I add all the quarts of fluid. Do I have to temporarily remove the flex-plate and install a flywheel from a standard shift?
Sorry if this has been discussed before, but I did a search and couldn't find anything. Can anyone lead me in the direction of a solution?
Thanks!
--Paul
Thanks!
--Paul
