Why did they do this? It looks like its attached and vented into the valve cover ,and vented outside with that disc thingy. Weird"
Has anyone notice the pcv hose's somehow attach to the valve cover of a 259 ( 1955)
My understanding is that the engines for California distribution in the latter years ran a hose from the base of the air cleaner to the right valve cover breather cap to provide more positive crankcase venting at highway speed. Does anyone have a picture of this setup? I would like to duplicate it on my 259.
My car is a '63, sold, delivered, and spent its whole life in California. There's no setup like described above.
The PCV is screwed into the base of the carb (WCFB) and a hose connects to the port in the valley cover where the road draft tube went in earlier applications. That's how the shop manual diagram shows it, as well.
Originally posted by showbizkid View PostMy car is a '63, sold, delivered, and spent its whole life in California. There's no setup like described above.
The PCV is screwed into the base of the carb (WCFB) and a hose connects to the port in the valley cover where the road draft tube went in earlier applications. That's how the shop manual diagram shows it, as well.Gary L.
Before PCV's were mandated in all states they were required in California.
Several companies (AC-Delco comes to mind) made retrofit PCV valve kits that hooked up in different ways to different points on the engine.
When you see a PCV that hooks to the intake manifold, you usually see a separate hose from one of the valve covers to the air filter.
When you see this, the valve cover caps are NOT vented to the atmosphere. The clean air path goes from the inside of the air filter, to the engine crankcase near the valve cover.
Then, the polluted air gets drawn through the PCV valve into the intake manifold where it gets burned off in the combustion process.
Anything that got changed in the last 48 years could have compromised how the system was supposed to work.
HTIH
JeffHTIH (Hope The Info Helps)
Originally posted by studegary View PostWhat is being discussed is the earlier retrofit and select state (like California) applications that were just sort of stuck on/added on.
Originally posted by 14x7 View PostWhy did they do this? It looks like its attached and vented into the valve cover ,and vented outside with that disc thingy. Weird"Jim Bradley
Lake Monticello, VA
'78 Avanti II
Originally posted by showbizkid View PostAh, sorry for the misunderstanding. I thought the OP was referring to some sort of factory kit.Gary L.
That is not the disc that is on my car. This piece is no larger than say 2andhalf inches in diameter. It has a roughly 5/8 diameter nipple that is connected or actually tee- off . Here the hose is 1/2 to 5/8 in diameter, runs from the back of the intake manifold to right side of the right valve cover then that disc is a tee and vents into the right valve cover then tee's into the front of the intake manifold passage. My car was built in California. This is not connected to the valley cover in any way. I thought maybe this is a factory installation. It certainly looks that way with the tee off disc running into the valve cover . And the large hose makes it look obtrusive.
Something like this? http://www.mgexperience.net/archive/...al_USA/2176928Jim Bradley
Lake Monticello, VA
'78 Avanti II
Originally posted by 14x7 View PostThat is not the disc that is on my car. This piece is no larger than say 2andhalf inches in diameter. It has a roughly 5/8 diameter nipple that is connected or actually tee- off . Here the hose is 1/2 to 5/8 in diameter, runs from the back of the intake manifold to right side of the right valve cover then that disc is a tee and vents into the right valve cover then tee's into the front of the intake manifold passage. My car was built in California. This is not connected to the valley cover in any way. I thought maybe this is a factory installation. It certainly looks that way with the tee off disc running into the valve cover . And the large hose makes it look obtrusive.Gary L.
I have one or two valve covers at home with an aftermarket PCB setup similar to throne described. I will try to dig them out if I still have them. From memory they have a hole in cover that has an attached, by two pop rivets, flange. The hose attaches to that flange somehow. These are from California cars. One is definitely1963.
