All this is on a 52K mile 60S-W4.
Finally got some time in August to put on the SS exhaust system I had picked up at York. In taking one of the nuts off the header pipe, snapped the bolt off in the manifold. With a local club member/good friends help, we were able to get he old bolt out and new studs in without problems.
Two weeks ago, I put everything together and started it up expecting to hear a nice mellow tone out the tailpipe - only to be disappointed by exhaust leaks from the manifold at the bottom of both central exhaust ports where they meet the block. I knew the mounting surface had looked kind of iffy, so off it came again to go to a machine shop for some "truing" up. They called yesterday to say it was finished.
Zipped everything up again this afternoon, double checked to see if anything was out of place - and almost threw a wrench through the wall of the garage when it was again leaking at the block/manifold - only this time it is leaking at both end exhaust ports.
I ordered a NOS gasket (one that is flat metal all the way across with a white material between that and a raised metal are). The orientation of the gasket was the same as the one that came off: Long flat side against the block with smaller raised area toward the manifold. Guy at the machine shop asked what kind of sealer I was going to use - then told about something some of the engine builders use that is good to 2500 degrees - but I thought those gasket always went on dry so I did not worry about it...
Just keep torquing it down might sound like the right thing to do, but the nut holding it on are brass - so there is a point of no return on that route.
So - for those who have fooled around with these motors, any ideas? When my wife was told what was wrong, she pointed to a 289 sitting in the garage and stated - "why don't you just put that thing in there..."
Thanks ahead.
Thanks ahead.
