I have a early 50's side valve may be a commander or even a 2r engine which has quite a few bits in the box.
1. There is a canister oil filter unit where does it connect ? I do have a thin metal pipe coming off the oil pump, is that a pressure gauge or for the oil canister ? if so which end of the canister does it go.
2.Once the oil gets in the canister assuming it comes out where does it go back into the engine ?
May be a good picture would answer the above.
