While driving to and back home from South Bend, my Hawk got Hot, never before has the temperature gauge reached that 210-220 degree mark due to the ambient air, road temperatures and constant 2500 RPM for hours between stops. I was freaking out,... running the heater full blast for miles trying to cool her down a few degrees while forcing my hot girlfriend into the back seat with the recliners fully down and hugging her ice tea.
I did stop in Canton, Michigan on the way home to check out a deal on a rebuilt Eaton power steering pump for a $102 with a core, and it came with a filter. This pump is the exact same as the 1964 Mustangs. I went in asking for an Eaton pump, the guy asked "for what year etc, .etc" . Actually it's for a 1964 Studebaker, just like the one out there in the parking lot". I then showed him my core and he came back with a new pump in a box. I looked it over so did he then I checked the bolt that holds the reservoir to the body and the pressure outlet size and it was perfect match. He took the core and I was happy.
I then asked him about an axillary rad fan and bought a 12", then wired it up in the parking lot, without a shade tree around. Even with the fan installed, (I installed it pushing due to just wanting to get back on the road) it did not add to any significant cooling once back on the road. I think this would be a better installation with it pulling, so when I pull the waterpump, think I will re-install the fan on the other side of the radiator and it will be totally out of sight.
Pulling my waterpump will enable me to check the impeller for correct clearances making sure I have good coolant circulation before driving any distances again in these temperatures. If all that checks out okay I guess its time for a re-core.
I guess the big question for me is What is that magic temperature "meltdown" number?
Allen
Allen
