I experienced something totally unexpected today. While sitting in traffic, Barney simply... shut off. He started right back up again, but I'd like to figure out what caused this.
Here's the configuration: 259 4bbl with FOM, less than 3000 mi. on the rebuild.
When this happened, the car was fully warmed up after about 1/2 hour on the road. I had just stopped to fill the gas tank and had idled for about 5 minutes waiting to get back into traffic. Warm day, about 76 degrees, temp gauge showing just a touch warmer than the middle of the scale due to the shutoff / restart / extended idle cycle. I had just pulled into traffic and immediately got stopped by a red light, and was idling with the nose of the car pointed slightly downward when, all of a sudden, the engine just shut off, like I'd turned off the key.
I shoved him into Park and he immediately fired back up and ran flawlessly, so it's not vapor lock.
With all that information... any clues? I'm leaning toward the voltage regulator, but I'd love your opinions.
Thanks!
- Rebuilt Delco distributor with new Uniset points/condenser.
- Freshly rebuilt WCFB installed at rebuild.
- New OEM-spec coil.
- New ignition switch.
- Complete re-wire.
- External ignition ballast resistor - no resistance wire in the harness.
- New mechanical fuel pump with the rebuild.
- Freshly rebuilt Prestolite alternator, fully charged battery.
- Solid-state voltage regulator, Chrysler-style.
- Only electrical ignition parts NOT replaced are solenoid and voltage regulator.
Thanks!
