I have always understood that the '63-'64 Avanti Water Pump not only fit Avantis, but that it was the preferred water pump for all Stude V-8s from 1951-64. But I just noticed in the Studebaker International catalog this note next to their part # 1560395, "Fits Avanti only, not used on other R-eng. cars."
Is this really true or a mistake in the SI catalog? Also, does anyone know if all vendors are using the same supplier for new and rebuilt pumps? If there are different suppliers, which suppliers/vendors have you had good luck with? I ask because I have what what appears to be a new pump (bought enough years ago that I do not remember where I purchased it). This pump has enough problems that I am afraid to use it. For instance, the diameter of the hub of the pump is about .005" over what it needs to be to fit into the fan clutch. Also, the impeller was too close to the body of the pump, and after pulling it out to where it should be, the end of the pump shaft is recessed into the impeller 3/8" instead of the end of the shaft and the impeller being more or less flush. After breaking it free while pulling the impeller out, it moved more and more easily as I pulled it, and that makes me wonder if the impeller might be in danger of coming off the shaft while in operation.
So I am considering getting a new pump, but I want one that is made and assembled correctly this time. All ideas are welcome.
