Hi, Guys,
The passenger door is on the Avanti, but I'm having some trouble aligning it. It's about right fore and aft, and about right up and down. The back side clicks onto the striker perfectly and is about the right depth. The problem is the front edge. The front side is about 3/8 inch too far outboard at the top and 1/4 too far out at the bottom. The gap at the top of the vent window is about 1/2 inch.
The first time I put the door on, the bottom was actually too far inboard while the top gap outboard was almost an inch. I shimmed the bottom hinge out, which made the gaps less extreme, but the entire front edge is now protruding. There are no shims on the top hinge. Because there are no shims on the top hinge I cannot figure out how to bring the top edge in.
Any of you pro body men have ideas on how to draw the front edge inboard?
Thanks, as always,
Tom
Thanks, as always,
Tom
