In the process of putting my suspension back together on my 60' Lark. I am installing the lower outer pin's bushings. I've prelubed the bushings with grease, installed the spreader tool, (.015) I even watched my dial indicator as I spread the control arm out. I tightened up the caps, 1/3 turn each side, tightened both sides up evenly. Once both caps were tight, I torqued to 65lbs and removed the spreader tool.
The manual says the lower support "Should move freely" Well, mine does, but not by hand, with a cheater pipe. I am under the impression that I should be able to move the lower support BY HAND once its tightened.. correct? If so, what step am I missing?
Thank you all.
Thank you all.
