Hi, I have a old R-1 engine that I want to rebuild to install into a Hawk. Can I use the old cam shaft if it looks ok?
Can I reuse my camshaft
If it does not look quite up to snuff, you can send it to almost any cam company and have them put a light resurface on it. I had my stock cam reground to a much more aggresive performance grind at Isky and it was only $95.00. Likely would be less for a resurface. Also resurface the tappets if you resurface the cam, it will be almost like new.
it doesn't sound like you've received your fullest advise...namely: you need to have your cam measured/miked out/checked by a good shop to see if it is worn out of spec......I once had cam bearings disintergrate and it left one of the cam journals slightly worn.....gl
FWIW, I know of more than one regrind shop which will take in an R1 cam, but a true R1 regrind is not what will be returned. If they don't have the correct pattern, "closest one we've got" is what they do. A bit OT, but an explanation of how I know this. When I first started doing Packard V8s, the reground cam I got back wasn't correct. When I asked the shop, "Well, the Ford 289" cam is pretty close. You're the first one who ever noticed the difference."
jack vinesPackardV8
Thanks Jack, do you know some place that could do a good job on the cam and lifters? I have not had a R-1 engine before and I would like it to run well, I am putting it into a 62 Hawk with a 4 speed and a 373 TT rear. Thanks Terry
If your cam needs regrinding and you want to stay stock, ask Iskenderian to give you their E4 regrind. That's what Studebaker copied for the R1 cam. With the 3.73 and 4-speed, your GT would be a candidate for the Iskenderian ST5 regrind. It's just one step hotter than your R1.
jack vinesPackardV8
