Today I had my 259 Champ out at the feed store. After loading I turned the key and the truck lurched. I had left it parked in reverse in OD. I neglected to put the clutch down or shift to neutral. I was trying to start in reverse in OD, I know not to do that. Anyway I released the key as soon as the truck moved. Then when I tried to start properly, turning the key gave no result, no click, no crank, no nothing. Fortunately I was parked on a slight grade and was able to start on compression and drive home. Turning the key still gets no results.
Where should I start looking?
