I am replacing the coolant expansion tank on my Avanti.
The Studebaker water neck I have has a water outlet that is 90 deg. (horizontal water flow). This neck causes the outlet hose to rub the power steering pump.
What I need is a neck that is at 45 deg. +/- to get the hose above the pump reservoir. Does a Chevy or Chrysler water neck fit the Studebaker mounting hole pattern? Any Suggestions?
Thanks
Thanks
