Did all V/8 Studes have an identical rocker arm ratio. Was it 1.0 to 1.5 ? Thanks, Dan
Rocker Ratio
Yes, all of the V8 Studes had the same rocker arm ratio. It was advertised as 1:1.5, but it was really a little less, something like 1:1.406. I guess, by the rules of rounding, it is OK to call it 1:1.5. Stude rockers were the hot set up for Cadillac V8 racers for a long time, may still be for all I know.
I got a call from Joe Panek over at Roto Faze machine a couple of weeks ago about the Studebaker V8 rocker arm ratio. Joe is working on an old Cadillac engine and he is installing Studebaker rocker arms on it as the owner wants them in place of the original rockers for more lift. I guess the Cadillac guys are still using Studebaker parts in their engines. Bud
Bud, not sure but I'm guessing the Cadillac boys liked the adjustable possibilities of the Stude rockers rather than the ratio change. I don't think the ratio was different, but Caddy always used hydraulic lifters and Stude solids. So if you wanted a Caddy to run you got a solid cam ground and used Stude adjustable rockers. I don't know that for a fact and would like to get that thought confirmed by your Caddy buddy if you get a chance. Thanks, Dan
Originally posted by whacker View PostYes, all of the V8 Studes had the same rocker arm ratio. It was advertised as 1:1.5, but it was really a little less, something like 1:1.406. I guess, by the rules of rounding, it is OK to call it 1:1.5. Stude rockers were the hot set up for Cadillac V8 racers for a long time, may still be for all I know.
Also another interesting point, these rockers were built to take to stock spring pressure of around 135 pounds open pressure. When I put a roller cam in the '51 and springs that were over 600 pounds open I used the stock rockers wondering if they would break the first time I started the engine. I ran them for about three years and not one broke.
Ted
Originally posted by Skybolt View PostTed,
Did you do any modifications to the rocker arms, like making them lighter, polishing them, shot peening them? Or where they stock standard?
Ted
