Push rods needed and other info.
  • Engine: Push rods needed and other info.
    I pulled the heads today to have the valves ground and found that I have 5 bent push rods on the 259.
    I see that SI does not list any, so am wondering if anyone here would sell me some.
    I think the 232's are the same, if so I have plenty. I will check tomorrow.
      Be carefull...I believe the pre-259 engines used a different length pushrod than the post-259's.
        I check my manuals but they only cover 55-58. Those are the same part.
          The push rod length change was in early 1961 models. The prior length was in a range of 11-11/64" to 11-7/32" up to and including 61V-259" V-511,761 and 61V-289" P-74,841. Engine numbers after were 11-21/64" to 11-3/8" long.
            I have been contacted by someone with the parts and have agreed to purchase them.
            Thanks all.
              I know it is now a non-issue, but Studebaker International does indeed list push rods - on page 169. They show 527890 for 1951-Early 1961 (as explained in my post #5) and 1550303 For Late 1961 through 1964.
