Overhauling a Champion engine I came across a article frm Hemmings motor news ,May 2009.
The article states the 169.6 cu in straight six engine could have low oil pressure problems.
After the rod and main bearings were replaced the engine could still have low oil pressure problems .
This would be cause by worn lifters and lifter bores .
The remedy was to partially block the oil flow to the lifters.A restrictor was installed in the rearmost oil galley to accomplish this.
I can see how this would happen ,
I was looking for the clearance spec for the lifter to bore.??
Can oversized lifter be purchased???
Thank you
Thank you
