is there a K member out there that fits the 60 lark? I am curious because it would help with a lot of things for 1 and it prob would have a better suspension under the front too boot
K member questions
"K-member" sounds like a MoPar term, as I recall from people putting big blocks into Darts.
If you mean a replacement front clip, there have been lots of those done using various factory pieces (like Camaro) to get the power steering, suspension, and motor mounts, but there are also a few aftermarket companies doing the custom frame rails with the usual Mustang II suspension pieces, and the ability to keep your radiator and bumper mounts in place. A search for "front clip" or "fatman" may bring up some hits and hints.sigpic
JohnP, driving & reviving
60 Lark & 58 Scotsman 4dr
The Lark, as are all Studebakers...are narrower thAn most American cars.
Have I seen unmodified "clips" installed into Studes...ya...but the wheels/tires are out of place an or the wheels have a lot of offset to fit inside the fenders.
I haven't see any front crossmembers that will fit inbetween the stock Stude frame rails.
And..you must remember that the better handling cars will have longer control arms (like the Corvettes)..which make it more of a problem.
Just do some measuring on your car..(!), take a trip to your local wreaking yard...and do your own measuring.
Not that difficult..and can be an intertaning afternoon.
I'm thinking that the FWD 5th Ave's started in 1988 or 1989
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Originally posted by 52 Ragtop View PostI'm thinking that the FWD 5th Ave's started in 1988 or 1989. Jim
In 1990, the Fifth Avenue was "all-new" with Front Wheel Drive. BP
Most of the late 80s Mopar front track widths I looked up were 60 inches.
Richard Burks
53s
57 Transtar
64 Daytona 4 door (Wifes car Lucy)My 1st car. "A TRANSTAR"
Starliner
Somewhere between Culture and Agriculture
in the Geographic center of Tennessee
JDP had and sold a C/K that had the Volare K-member, bought at Reedsville a few years back. Seemed to be a good job. It was also MoPar powered IIRC. Here's the thread, although the pix no longer work:
Might ask him for info and a repost of the pix. I'd like to see it again!Proud NON-CASO
Romans 15:13
Deuteronomy 31:6
Proverbs 28:1
Illegitimi non carborundum
Originally posted by woodysrods View PostThis is good news.
Was it the same front end as the Volarie or is it narrower?
What is the track width?
Brian--------------------------------------
I can have a whole front of a mustang 92 if I want it will it fit? width wise?Last edited by mookandairin; 12-02-2011, 06:49 AM.
Along this line....
I have a 66 2 dr and the deeper I go into it the worse it gets!
I have replaced the floor in the car and the door post and while I was so deep into it, I wound up pulling the body off the frame, now I find the bottom plate rotted of in some places and the rear frame rails tweaked and torn, and while I have entertained installing a Mustang II front end ( I have heard all the + & -'s) this would not solve my problem as the rear frame is bent and rotted.
SO..... my question is, what was done to the Avanti to be able to use the GM frame under it..... would it be feasible to put that frame under a regular Lark?
Does anybody have pictures of a GM frame that was used under the Avanti?
I just want to get this on the road.....it's been close to nine years working on this!
Thanks,
KenKenneth Smolecki
