I have been asking question on this post about installing a 289 crank and pistons into a 259 block to make it a 289. I am understanding that all I need is a 289 crank and pistons and install them into my running 259 block. Is this correct so far.
I was looking at my cores and thinking studebaker tonight and I am wondering if the push rods used in the 259 are different than the push rods used in a 289? If piston comes up further in cylinder will it hit valves with 259 push rods? 1 engine is missing the push rods ?? made me think studebaker??? I want to use the core engine crank shaft too, provided no rust on it.
Provided rod and main bearings are same lets say stock. in 259 and 289 are rod and mains the same from both engines? I want to us pistons ( will keep mated to rods they are on) from the core engines I have, can get 8 good ones from 2 core engines, rering and use them.
I have a cam shaft from the core 289 that has no rust on it can I get it reground to have more duration and use it in the 259 I will rebuild?
Will using the engine number on block tell me year it was manafactured (how) would like to change to breakerless points want to get correct set 1st time.
The water pumps look different too at least how they connect to the block what should I use 259 or 289 off the core engine. All blocks\cores I have are not full flow.
