Has anyone had a failure using the replacement O-Ring found in some of the SASCO kingpin kits?
Rubber O-Ring vs Cork gasket
Front Axle / Front Suspension: Rubber O-Ring vs Cork gasket
Tags: None
Never had a failure, and o'ring is all I have used for years. I recently refurbished the front suspension on a GT Hawk that had about 150,000 miles and 15+ years since last refurbishment. The o'rings were square but still pliable; probably coulda re-used them, but of course installed new ones. Lester Schmidt turned me on to the o'ring trick many years ago.
Joe
Not somethiang I did. I'm having to redo for a customer and I was wondering if anyone had this problem before, or if perhaps it was something someone else screwed up? First one of these I've come across like this.
Originally posted by Studebakercenteroforegon View PostDid you install the lower needle roller bearing in far enough so that there was adequate space for the o-ring? I myself have sold kits with o-rings for 30 years and never had an issue.Bo
Bo,
I've probably done 10 of these kits with the o-rings. no failures that I know of, I don't see how they'd be a problem. IMHO I'd think the o-rings will far out perform the cork, unless as mentioned in a previous post that the needle bearing wasn't installed far enought but thats a GUESS.
Originally posted by bomarkham View PostNot somethiang I did. I'm having to redo for a customer and I was wondering if anyone had this problem before, or if perhaps it was something someone else screwed up? First one of these I've come across like this.
53 2R6 289 5SpdOD (driver)
57 SH (project)
60 Lark VIII 2dr sd (driver)
