OK: I just received my (used) throttle linkage and front pedestals for a 1965-66 Stude 283 from one of our vendors. rear crossmember I found locally.
Now for the questions: what radiator can I use? Someone here stated a Jeep CJ Chevy conversion unit is a 100% bolt-in.
Throttle linkage is the firewall mount style but, what's weird is my 1962 Lark firewall already has the appropriate mounting holes/flat surface from the factory, all I had to do was drill a hole for the bellcrank to pass through. It lined up with my pedal exactly and bolted right in.
Exhaust manifolds are generic Rams Horns; I already located a set locally.
Any thoughts on a AT tranny shifter for a TH350? I would like to stay with a column shift but, my present steering column is a 3 spd style and I know the AT Studes ad the 'suicide' Reverse selector versus the standard PRNDL pattern.
Final major question: what do you recommend for a numeric low rear end? I presently have a Dana 27 (tapered axle style, yuck) and would like to go with something different with slide off drums. Needless to say: I'm staying with the 5 on 4.5" bolt pattern wheels.
