I want to know the name of the post the door latch closes on to keep the door latched/closed. is it the striker? where can I find front fenders 1960 lark 2dr ht
door latch oin? what is it called?
Your car does not use a post like many other makes do.
Your car uses a Striker Plate . It is a plate with a little flipper and a
guide bar. Available from some of the vendors.Bill H
Daytona Beach
SDC member since 1970
Owner of The Skeeter Hawk .
Door lock strikers are prone to break if not cared for. Over time they are becoming scarce. Price reflects scarcity.
Good steel fenders will only be found by networking through the Forum, SDC, Turning Wheels or swap meets.
Classic Enterprises makes patch panels for the areas that are usually the first to go. If what you have can be repaired they are worth saving.
Additional option is fiberglass.
Brad Johnson,
'56 Sky Hawk in process
Originally posted by mookandairin View PostI want to know the name of the post the door latch closes on to keep the door latched/closed.>>>
Why "assembly" you ask? Because each Striker is "assembled" using six (6) different parts!
