Yesterday , my son , myself, and a Studebaker friend were installing a new Mallory
electronic distributor in a recently acquired Avanti. We brought the engine to the compression stroke
and checked the harmonic balancer timing mark was indicating TDC. After three hours of trying to
insert the dist. so that we had number one plug lined up with the rotor, and at TDC, we continually
failed to be able to get the timing mark to be placed closer than 25 to 30 degrees retard when we wanted
four degrees. Tried rotating the dist., moving plug wires, re-inserting, to no avail. Finally called Phil Harris at
Fairborn Motors and he advised the timing mark scribe might be mis-located and to use a dowel or
dial indicator to physically determine the TDC. Yipes! the scribed mark was off by more than 20 degrees.
We put our own mark on the balancer for TDC and were finally able to adjust the dist. to the 4 degrees although
the engine ran better at six. Lesson is ---on a 50 year old anything don't rely on anything factory having
not changed, even a scribed timing mark. BTW- Phil Harris is great !!
....Dick Curtis
....Dick Curtis
