Okay my 289 with 94k on the odometer uses a qt. of oil every 250 miles. all the plugs are light tan at the electrodes, two cylinders 6&8 are 120 psi on a compression test the rest are 135 to 140. the front seal is fixed with no leaks, only a slight leak at the back. if I was leaking that much the bottom of the car would be full of oil. I would think if I'm burning that much my plugs would show it. no blue smoke at idle, an ocasional small cloud on start up. If it where valve guides you would think I would have a cloud behind me while engine breaking down hill in third. Which I did plenty of on hiway 7 through Ar. on the way to springfield. yes my tailpipes are black but still that's a lot of oil. I'm using 10W30 Valvoline VR1
where is the oil going?
Hopefully, some of our engine guru's will chime in and have some experienced words of wisdom for you. I have overhauled a few engines, but I am not a technical junkie with a ton of scientific knowledge about these things. My experience comes from being too broke to pay someone else to fix things when they go wrong.
It is one thing to have tools, manuals, and the guts to jump in and fix something when it goes wrong, but really knowing what you are doing is another. I have the ability to take things apart, read instructions and put things back together in the proper order. I am not into polishing ports, re-jetting carbs, or grinding cams.
That said, I have had a couple of engines that used a good bit of oil without knocking, losing too much power or blowing a lot of smoke. My theory is that sometimes and engine can have a ring problem where it allows enough oil to pass into the combustion chamber with just enough "burn ratio" to fuel to actually burn the oil without a huge amount of smoke. On one of mine, some of the rings seemed to have lost their tension and were sorta hugging the pistons. Combine this with small leaks, draft tube loss, a little blow by, and it is possible to lose a good bit of oil in a short time without looking like the county skeeter patrol.
One thing for sure, you have a problem and until you find it...it aint gonna get better by itself. Good luck with searching for the problem and let us know what you find.
check rubber oil pressure hose to gauge line for a rupture. Located at rear of engine-passenger side cheers jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Check your PCV valve. Any and I mean any, crankcase pressure on an early 60's car with a PCV system will force oil past the rings. Also I would change to a single weight 40 oil with a can of STP. Even in 1966 my Hawk used a quart every 500-750 miles if I got cheap and left out the STP. I worked in a gas station (old full service kind) so I had access to cheap oil so it didn't cost me anything, but it never smoked at all either. Tail pipe ends were always black, never a fog. I guess the older engines burned the oil cleaner than the new ones!!!
STP has allowed me to drive my truck around the neighborhood. It reduced enough oil burning so that the plugs don't foul. Five minutes ago I parked the truck into the garage to pull the engine...
Maybe there is a microbe that is eating the oil, have you heard any burping coming from the engine?1948 M15A-20 Flatbed Truck Rescue
See rescue progress here on this blog:
http://studem15a-20.blogspot.com/
Originally posted by TXmark View Postthey still make STP?
I would think Richard Petty would still be hawking it, instead he selling BC powder.
thanks for the advice, I have not checked the PCV
Sounds like valve guides, combined with worn rocker arm shafts that allow oil to pile up inside the rocker covers until the guides are literally flooded, at which point even good guides and seals will let a lot of oil be burned. If the oil consumption gets worse the faster you drive, this is almost surely the problem.
Worn rocker shafts (and rocker arms) leak pressurized oil at a rate faster than the small drain holes at the rear of the head can drain it off. Oil builds up under the rocker covers until the valves at the rear of the heads are literally swimming in it. When it gets real bad, you may see signs of oil blowing out the filler cap on the right side.
I have had this happen. Plugs usually don't show much sign of oil fouling, because the burning happens most at high speeds, and the oil does get completely burned. The engine will run well, and test good for compression.
If the engine shows normal oil pressure for a warm engine at cruise, and then the gauge starts to fade or flicker towards zero on a sustained high-speed run, you will know you have pumped most of the oil in the pan up to the heads, and the pump pickup is starting to suck wind. That is the clincher.Gord Richmond, within Weasel range of the Alberta Badlands
What can one do about repairing worn rocker shafts & arms? Are new replacements available?
My '63 289 smokes a lot until it has reached full operating temperature (180 F or there abouts) but also smokes when engine braking and consumes a lot of oil when driving 65 mph or faster. Despite this, the engine runs excellent and has good power.sigpic
In the middle of MinneSTUDEa.
First and least expensive is to install new umbrella seals. These can be done without removing the heads.
If, after this, the oil consumption is still greater than you can accept, a complete head rebuild; cleaning, milling, new valve guides, new valves, positive valve stem seals, would be the way to go.
http://www.rockerarms.com/rockerarms.com/Home.html can rebuild your rocker arms and shafts.
jack vinesPackardV8
Further on the comment about the rubber portion of the oil line going to the oil pressure gauge ---- sometimes this will only leak when the engine is operating an road speeds. When you check it, have the engine running. If it doesn't leak at idle, move the throttle linkage so that the engine is running fast. If there's a leak, you'll soon see it --- and probably the surrounding part of your engine compartment already will be "undercoated".Bill Jarvis
Do not under assume this is not your problem
My car did 100 miles per quart of oil because of this situation. jimmijimOriginally posted by Greenstude View PostFurther on the comment about the rubber portion of the oil line going to the oil pressure gauge ---- sometimes this will only leak when the engine is operating an road speeds. When you check it, have the engine running. If it doesn't leak at idle, move the throttle linkage so that the engine is running fast. If there's a leak, you'll soon see it --- and probably the surrounding part of your engine compartment already will be "undercoated".sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Originally posted by TXmark View PostOkay my 289 with 94k on the odometer uses a qt. of oil every 250 miles. all the plugs are light tan at the electrodes, two cylinders 6&8 are 120 psi on a compression test the rest are 135 to 140. the front seal is fixed with no leaks, only a slight leak at the back. if I was leaking that much the bottom of the car would be full of oil. I would think if I'm burning that much my plugs would show it. no blue smoke at idle, an ocasional small cloud on start up. If it where valve guides you would think I would have a cloud behind me while engine breaking down hill in third. Which I did plenty of on hiway 7 through Ar. on the way to springfield. yes my tailpipes are black but still that's a lot of oil. I'm using 10W30 Valvoline VR1
It turned out to be the exhaust valve seals, thus the oil never burnt and made smoke since it was introduced after combustion.Ron Dame
'63 Champ
