Good evening, all. I copied down all the markings from my 51 Champion axle, and did not see a clear guide on reading the housing or tag markings:
Raised numbers on the housing, 26
On a metal tag, attached about 2:00 position: W 46
13
On a larger tag: Hypoid Lub
Is this a Model 26? Can I tell what ratio this is from the information above?
This is a Champion with a DG-200 automatic, if that matters. When I get the transmission rebuilt, it will get a new governor, and I need to see what kind of gear(s) I might need for the speedo - had the speedo rebuilt, new cable core, still nothing. But with a later (1953) model transmission in it, I want to be sure to get the right speedo gear(s).
Regards,
Clarence
Virginia Beach
13
Regards,
Clarence
Virginia Beach
