Today I finally got around to start changing the motor mounts on my lark (rears already done) and found something very interesting and a little scary. I pulled out and replaced the driver side one with no problem, when started on the passenger side I could see that the engine side tab but bend up and at steep angle. After the nut on the bottom of the mount was removed the whole top side of the mount started moving freely (before I lifted the motor). I removed the motor side mount bracket to find the problem and after the first front bolt was removed the entire mount came out, it had sheared off right through the back mount hole making the brace on the back useless. Basically the mount was no longer holding that side of the engine and for the past year or so im guessing the engine oil pan was sitting on the steering arm and holding half of the weight of the engine. After some welding today I have it back together and tomorrow ill see if it still fits in and hold. Has anyone seen, heard or had this happen before? Thanks everyone!
