dual MC and 4w disc brakes
  • dual MC and 4w disc brakes
    I now have 4wheel disc brakes on the 63 cruiser. It has the
    factory booster. Anything special I should know for operation
    when converting to a dual master cylinder on the booster?
    64 Champ long bed V8
    53 Hudson Super Wasp Coupe
    Got a proportioning valve on the rears? Residual check valves on both lines? I did tnis recently, and it was pretty straight forward, but I read a lot of the old posts for research.
    Las Vegas, NV
      Not really .. use an Avanti II master from an early 70s Chrysler. Its
      about 70 bucks.
      Tom
        Kerry, did you get the info I sent you?
          4 wheel disk brakes will require a MC, with larger than a 1.0" bore. Use this as a reference to calculate how much fluid you need to push before buying a MC
          This page only addresses Stude brakes, but you can see the message...
          Bob Johnstone
          64 GT Hawk (K7)
          1970 Avanti (R3)
            Thanks for all the info guys! I still like to ask in case I miss
            something.
            Mike, I PM'd you.
            53commander HDTP
            53 Champion HDTP
            61 Cursed Purple Hawk
