dual MC and 4w disc brakes
  • dual MC and 4w disc brakes
    I now have 4wheel disc brakes on the 63 cruiser. It has the
    factory booster. Anything special I should know for operation
    when converting to a dual master cylinder on the booster?
    64 Champ long bed V8
    53 Hudson Super Wasp Coupe
    Got a proportioning valve on the rears? Residual check valves on both lines? I did tnis recently, and it was pretty straight forward, but I read a lot of the old posts for research.
    Las Vegas, NV
      Not really .. use an Avanti II master from an early 70s Chrysler. Its
      about 70 bucks.
      http://www.studebaker-info.org/tech/repstuavMC.html
      http://www.studebaker-info.org/text3/AvantidualmcCB.txt
      http://www.studebaker-info.org/text3/AvantidualmcSG.txt
      Tom
        Kerry, did you get the info I sent you?
          4 wheel disk brakes will require a MC, with larger than a 1.0" bore. Use this as a reference to calculate how much fluid you need to push before buying a MC
          http://www.studebaker-info.org/tech/.../brakswept.txt
          This page only addresses Stude brakes, but you can see the message...
          Bob Johnstone
          64 GT Hawk (K7)
          1970 Avanti (R3)
            Thanks for all the info guys! I still like to ask in case I miss
            something.
            Mike, I PM'd you.
            53commander HDTP
            53 Champion HDTP
            61 Cursed Purple Hawk
