Pertonix for prestolite distr.?
  • Pertonix for prestolite distr.?
    Is there a Pertonix module for a prestolite distr. in my '56 259? What is the part No#? Thanks!
    John Ratliff
    Give Fairborn Studebaker a buzz...
    Bellingham, WA
      John Ratliff
      Check with Phil Harris (Fairborn Studebaker) at stude6@yahoo.com (937-878-1576).
      Are you sure it is a Prestolite? The original in the '56 would have been a Delco. If it is a Prestolite, I don't think Pertronix makes one for the single point Prestolite. If it is a Prestolite and Phil doesn't have anything for it, I have a Crane unit that will fit if you are interested in that.
      Ted
        Per Pertonix web site lists a # 1584 for a Prest.Dist..here is a link
        Bluehost - Top rated web hosting provider - Free 1 click installs For blogs, shopping carts, and more. Get a free domain name, real NON-outsourced 24/7 support, and superior speed. web hosting provider php hosting cheap web hosting, Web hosting, domain names, front page hosting, email hosting. We offer affordable hosting, web hosting provider business web hosting, ecommerce hosting, unix hosting. Phone support available, Free Domain, and Free Setup.
          Pertronix info: The 1187LS is for the non window Delco distributor used on V8 Studes from '56 through '61 (and can be adapted to the '53 through '55's also if converted to 12 volt). Pertronix also has one for the 6 volt V8, '51 through '55) but I don't recall the part number but Phil has them.
          The '60 and '61 Larks and trucks used the Window Delco and the 1181 fits those (the '60 and '61 Hawks used the non window Delco with 1187LS).
          The '62 through '64 used the SINGLE point Prestolite. Pertronix did not make one for this distributor. The Pertronix 1584 fits the R engines that had the Prestolite DUAL point distributors.
          Hope this helps clear it up.
          Ted
          John Ratliff
          Ted
            The 6 volt (positive ground) units are Pertronix #1188P6
            Bob Johnstone
            64 GT Hawk (K7)
            1970 Avanti (R3)
              I installed one (No. 1188P6) in my '53 coupe last month. Had a bit of trouble, but the techs at Pertronix helped me until it was working. They also helped getting the OD wired correctly.
              Tom Bredehoft
              '53 Commander Coupe
              '60 Lark VI
              '05 Legacy Ltd Wagon
