I know, I know, this topic has just about been done to death. I understand the whole dialing in process, and being a fitter machinist have the gear and ability for it not to be a big job. But, my question is - if you remove and reassemble the same bellhousing on the same block surely the locating dowels will ensure a fit within 0.001", even less. Of course allowing for it to be the 1st time apart since factory assembley. (In this instance I'll be seperating a FOM from a 289 '62 GT engine). Please point out if I am on the wrong track.
Yet another Bell Housing Dial In question.
Tags: None
Matt,
Your thinking is correct & the bell housing should mate back with the engine block within the tolerances specified. The problems that have occured over many many years is when the engine or auto trans have been changed & the owner has not dial gauged the new combination due to ignorance or laziness. Then the converter plates have undue stress placed on them.
Trust you had a nice time at Phoenix. Jim.
\"QUIGLEY DOWN UNDER\"
MELBOURNE.
'morning Jim,
Thank you for confirming my theory. Having used locating dowels, parallel & tapered, over the years to align machine components to the same tolerances, I just couldn't see how re-dialing would be necessary at each re-assembley, (allowing for any ware of course). But what you said makes perfect sense.
Yes, we had a great time at Glendale. I wish I had a dollar for every time someone, after hearing my accent, asked if you had attended ;-) I'm sorry we didn't catch up, but I'm sure we'll meet around the traps sometime in the future. Maybe later this year, my wife is planning a trip to Melbourne sometime in Nov / Dec, and I'm sure I'll be seeing Brian and Leon while she does her 'Arty' stuff. (She is a Textile artist).
Matt, did I meet you in Glendale and not know it? I was with Ian Mackellar all week, and at times with Brain and Leon, also the Mosley's getting my age I sometime forget peoples name, Ian has talked about maybe next year bringing his family again, he did in 07 at South Bend all went in the motor home and pulled the Avanti behind, also stopped at the Salt Flats track for a run...BobCandbstudebakers
Castro Valley,
California
Originally posted by candbstudebakers View PostMatt, did I meet you in Glendale and not know it? I was with Ian Mackellar all week, and at times with Brain and Leon, also the Mosley's getting my age I sometime forget peoples name, Ian has talked about maybe next year bringing his family again, he did in 07 at South Bend all went in the motor home and pulled the Avanti behind, also stopped at the Salt Flats track for a run...Bob
Yes we met, I was the third guy with Brian and Leon. I came to your house & shop with them to look at the cars you had, then spoke to you and Ian a couple of times in Glendale. But don't beat youself up about not remembering me, I've got one of those forgettable faces ;-)
