Not to open a can of worms but I was parting a '63 Daytona conv. rot bucket and pulled the power brake and master. It's a MASTERVAC and correct '63 only master. I need to mention it's a NON-DISC car. What I noticed was the shorter pushrod and NO ECCENTRIC bolt at the pedal. I have later '64 type set-ups and noticed the later years had both a longer pushrod as well as the eccentric bolt. I went through this due to adding power brakes to my '64 wagon. I also noticed that the longer pushrod is stamped with an LD 1 and there is no marking on the shorter '63 style. Any other thoughts from folks who have been through this. This is not the first unmolested car ( '63 ) that has had this power brake set-up with no means of adjusting the brake pedal to align with the clutch pedal or move it up from the floor/toe board. Yes the pedal has 2 holes but that wouldn't be enough even in the upper hole.
Rob in PA.
Rob in PA.
