Can a one-piece '51 Champion windshield be installed in a '50 Champion by removing the center post? That was a common trick with early 50s GM cars, removing the center post from a '52 Chevy and installing a one-piece '52 Oldsmobile windshield. Can a similar thing be done with a Champion, or is the roof shaped differently? Just curious. Thanks.
'50 Champion windshield
Tags: None
The window frame is shaped different then the 2 piece windshields along with the roof and cowl area. If you had a section of the roof and cowl from the 51, you might fabricate them into the 50 to to use a 1 piece glass.
My 50 Champion Starlight Coupes and my 50 convert are one piece. My 50 4 Dr is 2 piece.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
I like the classic old car look of the divided windshield, and it's easily available if one side gets damaged.
Just the other day I was wondering about the availability of the curved windshield in my 50 Land Cruiser, if something happened to it?
Two piece vs one piece windshield
Originally posted by dstude View PostCan a one-piece '51 Champion windshield be installed in a '50 Champion by removing the center post? That was a common trick with early 50s GM cars, removing the center post from a '52 Chevy and installing a one-piece '52 Oldsmobile windshield. Can a similar thing be done with a Champion, or is the roof shaped differently? Just curious. Thanks.
Originally posted by dstude View PostCan a one-piece '51 Champion windshield be installed in a '50 Champion by removing the center post? That was a common trick with early 50s GM cars, removing the center post from a '52 Chevy and installing a one-piece '52 Oldsmobile windshield. Can a similar thing be done with a Champion, or is the roof shaped differently? Just curious. Thanks.Gary L.
