After trying all possible combinations of alignment I finally gave up and added a CV joint into my drive shaft.
I could not get rid of the take off shimmy.
The new setup is 1deg on the transmission end, 4deg on the center (CV) and 1 deg on the diff end.
Because the CV joint is "constant velocity" the 4deg can be ignored.
And bingo, its as smooth as silk.
The top one is the original Studebaker shaft. (modified to suit my 60 Hawk)
The bottom one is the new one with a rubber mounted bearing.
Allan
Allan
