The car started to run roughly and when I opened the hood I could hear a hissing sound. I checked all connections but couldn't find any visible problem. Then I went on to our forum and it seems to be an intake manifold leak. I don't know if there's a hole in the manifold or if it's a bad gasket, as it would have to be put on a hoist in order to see it. Is it okay to keep driving it until i can get it looked at?
Hissing sound
Which engine do you have as the V8 engines don't very often have an intake manifold leak. The sixes can have gasket failures but it's usually on the exhaust ports of the gasket. If you suspect an intake leak, don't keep driving the car as an intake leak can cause the cylinder or cylinders that have the leak to run lean which isn't good. Bud
Another way to check is with a propane torch. Turn it on slightly, don't light it. Move the nozzle slowly around the intake manifold and the base of the carb with the engine running and the air cleaner in place. If the engine speeds up, that's where the leak is -- the leak is sucking in the propane and burning it.Skip Lackie
Originally posted by plee4139 View PostThe car started to run roughly and when I opened the hood I could hear a hissing sound. I checked all connections but couldn't find any visible problem. Then I went on to our forum and it seems to be an intake manifold leak. I don't know if there's a hole in the manifold or if it's a bad gasket, as it would have to be put on a hoist in order to see it. Is it okay to keep driving it until i can get it looked at?Sorry, I couldn't resist that one. I agree with the carb cleaner or 2+2 method of checking.
JSLast edited by LarkTruck; 05-18-2018, 03:20 PM.I was STUDEBAKER, when STUDEBAKER wasn't "KOOL".
A hissing loud enough to hear easily does sound like a hose has come off or is cracked. The diaphragm in the distributor vacuum advance could also have ruptured. Try blocking/capping any vacuum ports to the carburetor or intake and see if the engine runs okay. Then connect them one by one and see when the problem resurfaces."In the heart of Arkansas."
Does your Hawk have power brakes? The hissing noise may be coming from the vacuum line or the booster.
As said, this is most likely a vacuum leak somewhere. If it is enough for you to hear it, do not run the car much at all until repaired due to the lean condition in one or more cylinders.
I can't think of anything that would cause this on your car that would require the car to be elevated in order to diagnose the problem.
Also, it may not be a connection, but could be a split in a vacuum hose.Gary L.
Fears of welding or having to replace an intake manifold or installing a brand-new gasket were not , praise the Lord of Your Choice, The unwanted hissing sound came from the opening in a small L-shaped tube on the top of the 289 block which was missing a cap, thus causing the sound. It looked like there should be some kind of rubber or metal tube connected to it, but evidently not. Anyway, my shop handed me a bill of $54 and change, and then I handed back a coupon for $50m from them, and the rest was a wash. Thanks for your informed input.peter lee
I am pretty sure it was not in the "BLOCK", ...no Vacuum there.
Most likely a brass fitting for a Power Brake System that had been removed and the hole in the INTAKE Manifold, left rear improperly plugged.StudeRich
Originally posted by StudeRich View PostI am pretty sure it was not in the "BLOCK", ...no Vacuum there.
Most likely a brass fitting for a Power Brake System that had been removed and the hole in the INTAKE Manifold, left rear improperly plugged.Last edited by plee4139; 05-24-2018, 01:24 AM.peter lee
