So last year I discovered that my original 2 row radiator couldn't keep up on a hot day with the AC running. When ambient temp was about 80 degrees or less the car would warm right up to 180 and then stay there. On hot days, 90 or more, the temp would constantly creep up even running 60 mph.
A very brief search revealed that a stock 2 row radiator ain't gonna get it done with AC unless you live in the artic. So I spent the money and had Griffen build me a replacement that has about 3 times the cooling capacity of the original.
Since installing the new radiator the car will never get up to 180 degrees. It warms up to about 165 and stays there regardless of AC on or off or temp outside. My first thought was that I had originally installed a cooler thermostat when I built the car. So I bought a new 180 thermostat and installed it. When I pulled the old one out it turned out to be a 180 degree as well.
Am I missing something here? The thermostat is obviously working because temp is being controlled at 165 degrees. What should I look for? When I installed the new radiator, I didn't do anything regarding the wiring. I don't see how the ground to the engine could have magically changed during the two weeks from the time I removed the original radiator unit I installed the new one.
Any thoughts would be appreciated.
